I bought an 87 GT a little over a month ago and it hasn't given me any problems until now. I thought I knew how to fix it but apparently I don't and I’m running out of money and patience so maybe you guys could help me out a little!
A week or two after buying the car the starter wouldn't turn the engine over on the first and sometimes a second try. I went on ahead and bought an Optima Red battery and the problem magically went away for a day! The next day it started doing the same thing. This time I replaced the starter Solenoid. All was great for about 3 days until a different problem arose. I started the car up and the starter kept running once the engine was started. After stalling the car I disconnected the battery but once I attached it back it kept doing the same thing. I took a voltmeter to the solenoid and noticed that it was stuck together. This time around I installed a new starter, starter cable and my second new Solenoid. It ran great twice then the starter kept running again and the Solenoid was stuck shut again.
I’m starting to get aggravated that I can’t pin-point the problem. Anyone have any ideas?
Thanks in advance! :SNSign:
I thought about that happening but I was lucky enough to have the quick disconnect battery cables, since of course the car wouldn't break down in the driveway and I had to run home and get some tools.
