87 LX T TOP
CONCRETEWARFARE
208
NEW YORK
Ok guys heres the deal. I need some opinions here to help me decide what I want to do. I have an 87 lx t top but I really want a notch. Im just not sure what it would be worth as a roller. Its got pretty decent paint on it and the body has around 60k on it. It has 4.30 in the rear and subframes. I removed all the hvac stuff under the dash and converted it over to mass air. For the right trade or price I might even let it go with the 90/10, 50/50 and 4 cyl springs in it. Basically im asking what you guys think I could get for this or if anyone would consider any trades for this. Also again another stupid question what do you think it would be worth whole? The bottom end is going to need to be replaced because the oil pressure is reading low but heres a list of everything its got if I sold it complete:
stock bottom end
FTI Camshaft
Brand new lifters
Trickflow 1.7 rr
AFR 165 58cc heads
Tmoss ported cobra lower
#30 injectors
Accufab 75mm tb and cobra upper honed to match
AFM N/A powerpipe
80mm Pro-m MAF meter
Fidanza aluminum flywheel
Underdrive pulleys
a/c delete
Spec stage 2 clutch
Aluminum driveshaft
4.30 gears
Electric fan
90/10
50/50
4 cyl front springs
subframe connectors
and probably a few others I forgot to mention
