89 5.0 GT hp ???? need help
wreckless5.0
I have an 89 Mustang GT with a decent amount of upgrades and was wondering about what im gettin out of it for hp, havent been anywhere where they have a dyno... performance mods include :
the engine is bored .30 over
Ford Racing wires
Ford Racing ECam
Trick Flow LS1 215 64cc heads
Trick Flow heat spacer
Trick Flow upper and lower intake
BBK throttle body ( 65mm ) with egr spacer
BBK headers
BBK h pipe
BBK cold air intake
Flowmaster exhaust system
MSD Ignition w/ TFI performance coil
Venom power chip
a/c delete kit
underdrive pulleys
so what do you guys think ? i'd appreciate the help..
it has trick flow LS1 215 64cc heads. I thought i listed them.. i knew what iw as doing when i built this but im just curious as to whats shes pushin for hp.. im only 22 and have sunk a great deal into this car and cant afford for someone to take it to dyno it... ive also never took it down the track im not near any.. just smokes just about anything ive put it up against
Get a bigger maf 75-85mm and 70-75mm t.b. and injectors 24#-30# the injectors are maxed out more than likely. You are probably in the 400-425 flywheel hp 310-330 rwhp assuming you have every bolt-on you can get for it. (headers, u.d.pulleys, no smog, ele.fan) :nice:
my bad i was on the sheet of my dads car.. there trick flow high port 225s.. nothin special but better than stock... my buddy had given them to me.. thanks for the helps guys.. whats next ? supercharge it or do the twin turbo setup ? which would you run ?
