Fox 89 Coupe
  • Thread starter Thread starter txfivelitercoupe
  • Start date Start date Nov 8, 2014
T
txfivelitercoupe
  • Nov 8, 2014
89 5.0 030 over flat tops with dish,351w pro comp 3037 heads.remachined with twin springs.Edelbrock performer rpm carb. Intake .600 carb.e303 cam.bbk headers.hei distributor conversion.3.08 with t5. Any guesses on horsepower or 1/4 time ?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 8, 2014
  • Nov 8, 2014
Do you own this car or are you consider buying it?
If you own it, did you build from scratch or buy someone's project?
HEI distributor? Are you still using the original EFI distributor with a GM add on ignition module?
T
txfivelitercoupe
  • Nov 8, 2014
Yes I bought it from someone.the heads had to be fixed.flash burned on head gasket.milled them 010 and replaced all valve train.pistons are 030 .seen it myself
T
txfivelitercoupe
  • Nov 8, 2014
Used 69 boss 302 head gaskets with arp
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 8, 2014
  • Nov 8, 2014
What about the distributor?
Lou95gts
Toronto
Nov 9, 2014
  • Nov 9, 2014
275 hp 13.50@103mph
T
txfivelitercoupe
  • Nov 9, 2014
The distributor is electric ignition with vacumn advance
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Nov 9, 2014
  • Nov 9, 2014
you need to provide more information. gears, trans, weight of car, suspension, etc.
T
txfivelitercoupe
  • Nov 9, 2014
Stock weight.subframes 3.08 gears.other tahn
T
txfivelitercoupe
#10
  • Nov 14, 2014
  • #10
302 030 over .351w pro comp heads.b303 can.hei distributor with vac. Advance.edelbrock 1405 carb.bbk headers.twin valve springs.2.02 intake 1.60 exhaust. 1.7 rockers .3.08 gears 2980 weight 5 SPD.subframes .king cobra clutch. Any estimates on horsepower or 1/4 times ?
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Nov 14, 2014
#11
  • Nov 14, 2014
  • #11
About 275 rwhp and depending on tires,suspension,your driving ability,and the track could run in the mid to low 13's. You need more gear ratio like a 3.73 or 4.10 if you're just concerned about track times.
T
txfivelitercoupe
#12
  • Nov 15, 2014
  • #12
Thanks.I am considering 4.10s and maybe a 6spd conversion for daily driving I only work a few miles away..at ford .also I have draglites all the way around .15x8 on rear runners up front.my rear spacing is only 3.5 deep.I have seen the 5.5 offset.will it fit with 10.5 slicks without tubs ?
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
