Fox 89 Coupe
txfivelitercoupe
89 5.0 030 over flat tops with dish,351w pro comp 3037 heads.remachined with twin springs.Edelbrock performer rpm carb. Intake .600 carb.e303 cam.bbk headers.hei distributor conversion.3.08 with t5. Any guesses on horsepower or 1/4 time ?
Do you own this car or are you consider buying it?
If you own it, did you build from scratch or buy someone's project?
HEI distributor? Are you still using the original EFI distributor with a GM add on ignition module?
302 030 over .351w pro comp heads.b303 can.hei distributor with vac. Advance.edelbrock 1405 carb.bbk headers.twin valve springs.2.02 intake 1.60 exhaust. 1.7 rockers .3.08 gears 2980 weight 5 SPD.subframes .king cobra clutch. Any estimates on horsepower or 1/4 times ?
About 275 rwhp and depending on tires,suspension,your driving ability,and the track could run in the mid to low 13's. You need more gear ratio like a 3.73 or 4.10 if you're just concerned about track times.
Thanks.I am considering 4.10s and maybe a 6spd conversion for daily driving I only work a few miles away..at ford .also I have draglites all the way around .15x8 on rear runners up front.my rear spacing is only 3.5 deep.I have seen the 5.5 offset.will it fit with 10.5 slicks without tubs ?
