What up Stangnet, I thought this was interesting. When I bought my car, it previously dyno'd at 369 HP to the wheels and 349 ft lb of torque.
Mods on the car when I bought it:
-Paxton SN93 (6psi)
-Anderson cam
-Edelbrock heads
-1.6 Rockers
-Cobra upper and lower
-75mm maf and 70 mm throttle
-Anderson power pipe
-24lb injectors
-255 pump
-3.73 rear
-stock bottom end
Mods I added:
-Went from 6.25" supercharger crank pulley to 7" pulley
-Mr Freeze meth kit (used medium nozzle)
-42lb injectors
-80mm maf
-electric fan
-aluminum driveshaft
With the addition of those mods, car dyno'd at 404 HP to the wheels and 444 ft lbs of torque, at 9 psi of boost. That's almost 100 ft lbs of torque increase! The tuner said that at 404 HP, my supercharger belt started to slip, because it's a 6 rib. He figured once I change to an 8 rib, the car will make about 450hp to the wheels. Just wanted to share, because before I bought the Mr. Freeze Kit, there was mixed reviews on it. I think for the price you can't beat it! Plus my tuner said he actually likes that kit because there's no electric pumps to go bad, etc... Let me know what you guys think. Joe.
-Paxton SN93 (6psi)
-Anderson cam
-Edelbrock heads
-1.6 Rockers
-24lb injectors
-255 pump
-3.73 rear
-stock bottom end
Mods I added:
-42lb injectors
-80mm maf
-electric fan
