I just got an 89 lx new 306 ported e7's the car was built by a local speed shop. The motor only has near 1,000 miles. The motor shakes horrible off and on not all the time, and after getting on it it misses for the next mile or so. The car does not want to idle when first started. Wifey drove it to work only 1.5 miles away and calls back and said it died three times. I can not pull the codes because so much stuff has been removed from under the hood. When the car is running normal it pulls hard as hell. After letting the car warm up for about 5 mins. you can finally drive it but after about a mile it will start missing and popping through intake and miss bad. Timing is at 12 deg.
