89 Or 90 Maf Harness Diagram
det1990
hi im planning on putting a 5.0 in another vehicle i am working on the harness and none of the online diagrams seem to match my harness.
my harness has 2 round 8 pin connectors where the brown connector is on some vehicles
one is grey and one is black
grey has 5 wires
red/lt blue
red/green
white/pink
tan/yellow
purple
the black plug has 7 wires
red/white
blue/yellow
grey/red
white/purple
white/orange
red
tan/green
also the green plug near the ecu doesnt seem to match anything online either
it has 5 wires
orange/yellow
pink/black-
green/white
grey/yellow
tan or brown
any help greatly appreciated
Here are the plugs im talking about the green one is located near the ecu and the grey and black near the brake booster/ firewall on a foxbody the labeled diagram doesnt match my harness
PM me your email address and I will send you a complete Ford Factory 89 Mustang electrical diagram set. The zip file is 2.5 MB and is too big to fit through Stangnet's email gateway.
The plug shapes on the diagrams match the plug shapes on the actual plug. The diagram is divided up by the layout of the car. The first diagram is for the very front of the car, and it works its way to the rear of the car.
89 Mustang wiring diagrams zip package–
They are in a zip file format to reduce the size of the package. If you don't have Windows 7 or Windows 8, you’ll need WinZip or other Windows archive tool to extract them from the zip file.. See www.majorgeeks.com - Download Freeware and Shareware Computer Utilities for a free download.
The diagrams show the location area and the connectors are drawn to the same shape as those in the car.
You will need the Adobe Acrobat viewer which is also a free download – www.adobe.com/products/acrobat/readstep2.html - Adobe Reader download - All versions
There was never really a problem i just wanted to make sure i had the correct wires going to the right places
In reference to that green plug, I have the same wires but don't know what they goto, can you please help?
orange/yellow
pink/black-
green/white
grey/yellow
tan or brown
That member has not been see since March 19, 2017 so I doubt he will be checking in anytime soon. You need to buy this and that should list the wires:
Might get lucky and another member may have them already and will share.
Thanks. I'm ordering one but finally traced my issue to a bad fuel pump. About 5 years ago I bought a fuel tank and pump kit from LMR. I installed it and everything worked but other problems caused my car to sit for that time. I noticed a gas fume smell in the rear and when I crawled underneath I noticed the tank had a ton of corrosion and some small rust holes around the seam. I'm thinking moisture got in and killed the pump. My damn OEM tank didn't have any rust holes after 30+ years and this damn tank looks rotted. I have a new ACP tank which they say comes coated with corrosion protection but I'm thinking about buying a can of Por15 and painting the outside just incase.
