65FBE2
Side gears can not always be swapped between 28 &31 as the hole for the axel in the traction loc is to small to allow the 31's to fit. Also do do go swapping pinion supports from one carrier to the next with out knowing what you are doing. It sets the pinion depth into the ring gear. This is controlled by a set of shims that are specific to the carrier and pinion support. New gear sets will come with a marking on the pinion gear that will tell you how much to add or subtract from the shim pack with the new gears. If you loose the original shims or try and put a pinion support from another carrier you are on your own. This normally takes a differential specialist to get set up correctly.
