  • SN95 4.6L Mustang Tech
9 codes
  • Thread starter Thread starter Stang|ess
  • Start date Start date Aug 16, 2006
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Aug 16, 2006
  • Aug 16, 2006
I have:
P0122 Throttle Position Sensor circuit Low Input.
P0135 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0141 Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0155 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.
P0161 Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.
P0403
P0443 EVAP Canister Purge Control Solenoid or Valve Faulty.
P0440 Evaporative Emission Purge Control Solenoid Damaged.
P1000 OBD-II Monitor Testing Incomplete
P0122 one I understand, as I do P1000, but for the o2 sensors are these the rear ones? I have crappy mils installed so I'm thinking it's a problem with those. The EVAP stuff is coming at a surprize to me. How do I solve that? My gas cap is on, and I don't have a gas cap light error so i have no clue.
01Steeda
732
Baton Rouge, LA
Aug 16, 2006
  • Aug 16, 2006
could all be related to the crappy mils
atari
15
Canal Winchester, Ohio
Aug 16, 2006
  • Aug 16, 2006
P0403 = EGR Flow Circuit Malfunction
Thats all your o2 sensors, My guess is a Fuse or the ECU. I would clear the codes and see what happens. How long has the light been on? Some things go out then take other things out with them over time. I dont think your 02 MILs would make all that pop up. I have run my car without them and no cats and It was fine. Infact I still have heater codes showing after a year and a half. (I gave up on simulating the heaters) -atari
Stang|ess
Oct 18, 2003
941
Hawaii
Aug 16, 2006
  • Aug 16, 2006
I cleared them via xcal2 and they came back the next time I started my car.
I looked at the fuses, but have no clue what I'm looking at. How do I tell if a fuse is blown or not?
atari
15
Aug 16, 2006
  • Aug 16, 2006
Ok, Take it to a shop. Let them look at it. Please do not take offence to that. -atari
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Aug 16, 2006
  • Aug 16, 2006
Stang|ess said:
I have:
P0403
Check fuse number 8 in the central juntion fuse box.. NOT THE UNDERHOOD FUSE BOX this fuse box is inside under the dash.. it's a 20 amp fuse.
All those circuits are powered by EEC fuse #8... if it's blown and blows again remove your MILS and retest
remove this fuse and look at the metal part inside the fuse itself.. if it's broken inside you will see it when you compare it to another fuse. or just take a high detail pic and post it here.
Stang|ess
Oct 18, 2003
941
Hawaii
Aug 16, 2006
  • Aug 16, 2006
I had a CEL from my TPS for a while now so I can't say when the new codes came on. I wash my car every Sunday, and haven't cleaned the engine bay with any sort spray.
Are those for the front o2 sensor circuits? Haven't noticed the car running in limp mode, or a decrease in MPG.
Mike97gt
it doe snot
10,633
Aug 16, 2006
  • Aug 16, 2006
check that fuse I listed in the above post and post back..
Stang|ess
Oct 18, 2003
941
Hawaii
Aug 17, 2006
  • Aug 17, 2006
Yep, fuse 8 (20a?) was blown. It's pretty obvious when you compare it to a nonblown fuse.
Thanks a lot everyone
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
07 v6 4.0 wiring issue .In desperate need of help.
  • Staycstang
  • Sep 19, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Sep 19, 2025
F
Low fuel pressure downstream of fuel rail, good pressure upstream
  • FYWW
  • Feb 29, 2024
2K
SN95 4.6L Mustang Tech May 9, 2026
Cartel
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
Z
Electrical Problem - Help Needed
  • zworley_10
  • Apr 11, 2023
2005 - 2014 S-197 Mustang -General/Talk- Apr 11, 2023
zworley_10
Z
