ok, heres the deal... im swapping a 9" 28 spline, 4 pinion t-lock for the open diff in a 66. the rearend came from a 59 galaxie. the passengers side axle slid right in, no problem so far, right? move around to the drivers side, slide the shaft in place, hits solid about 3/4of an inch short. back out with the shaft, quick measurement, the shaft is now hitting the cross pin for the spider gears! riddle me this...do i need to cut the axle shaft to clear the cross pin? i have about 1/2" of spline left on the axle, so that shouldnt be an issue. has anyone else run into this, and how did you fix the problem?
