90 Lx Convertable Rear Window Motor Replacement
Man its been a long time since ive done one. Not too bad of a job though, if I remember correctly. Id just make sure that you replace the plastic dowels that hold the gears in place, youll see what im talking about when you take the metal gear off to transfer it to the new motor, you can get the dowels in a kit at most parts stores.
Like I said, not real bad, take your time and pay attention to what your doing.
Reactions: Tom Musso 90 lx
Easy peasy lemon squeazy
Remove the rear lower seat- push in with your knee and lift up
Remove the rear panels - i think 3 screws
remove the 3 bolts that hold the motor
unplug the wiring plug for the motor
If you are simply replacing motors. put some grease on the gears and lube the track and bushings for the channel
IF you rebuilding the old one- remove the cover off the old one, wipe out all the old grease and old plastic bushings and replace them with three 1/4 x 20 nuts- they will never break down and cause that rap rap rap problem with the plastic bushings. repack with grease, grease the gear.
Install the motor
Test window
repeat on other side
reinstall interior panel
reinstall seat
Reactions: aar0s
