90 Mustang 5.0 motor mount stud spins
mechman81
9
FL
How would I go about removing a motor mount stud that just spins? It's on the drivers side and the nut won't come off. My guess is someone over tightened it and caused this problem. Has anyone had this problem before or know how I can get it off?
Try this, put a jack under the engine, use a 2x4 placed on the jack and the oil pan rail where the bolts are, put some pressure lifting that side of the engine, use the weight to put pressure on the nut and use a breaker bar, not the air gun, to force the nut to grab some good threads
@mechman81
It's nut splitter time.... :)
The holes should span just about the same area as shown in the drawing; 1/8" holes work good for 5/16" and 3/8" nuts. A motor mount nut might need a pair of 1/4" or 5/16" holes as shown it the drawing.
Jrichker= refined, intelligent use of tools and skills when resolving issues.
General Karthief = backyard, knuckle busting use of tree limbs and stuff stolen from the neighbor that may cause injury or death and cost thousands in tax dollars to repair or replace.
Now who sounds like more fun at a party?
Here's a novel idea.....I assume you're trying to pull the engine. ( I mean,....why else would you need to unbolt the stud?)
Why don't you unbolt the mount from the engine, and pull the motor, then you can get to the back side of the mount?:shrug:
Reactions: Fordfreak93
That seems like a real PITA.
A torch may be able to cut it off. It's been a very long time since I've worked on factory style engine mounts.
I don't wanna risk a torch damaging the frame and drilling it from the side is impossible with it being recessed. I thought of using a Dremel with long extension with a cutting disc on the end. I'll attempt this wednesday and let yall know. Appreciate the help.
Reactions: 90sickfox
Guys I'll also be replacing the clutch and I have a question about pilot bearings. Are you supposed to fill in the crank hole with bearing grease to keep the bearing lubed or do you just leave it dry with what's already prelubed into the bearing? And what could it hurt to do this? Will it somehow sling out onto the clutch disc overtime?
That subject came up in a recent gathering of stangnet members to thrash on a engine/trans install, yes I was there and may or may not have been helpful, one member said he just 'jams that thing in there', one said he 'puts a little extra in just because' and the third one said 'whats a pilot bearing?' (I wonder who that was)
So, what do others do?
I put a little high temperature bearing grease in the pilot bearing. You don't want to use a lot because it can melt and get on the flywheel surface. If that happens it could ruin the clutch friction disc.
