90 mustang no spark
  • Thread starter Thread starter djj62478
  • Start date Start date Friday at 8:36 PM
djj62478
51
Nj
Friday at 8:36 PM
  • Friday at 8:36 PM
Im going crazy here, I was having surging issues and finally got the car somewhat straightened out and now this. I somehow lost spark, it started when I noticed the rpms jerking up and down sporadically causing the car to want to die out. Sometimes it will run when cold and die and not start back up when hot, other times it won't start at all. Checked a plug from the coil wire to a ground with nothing. Tried a new coil with no luck, got a used good distributor(or so I was told it was good didn't know for sure) it actually got a little better after I installed that but then reverted back. I ohmed out the tfi, then the tfi plug with a light tester, ohmed out the coil, all testing good. I thought maybe the thermal paste on the tfi dried up and that's why it ran when cold but not when hot. Unfortunately the tfi I ohmed out to be good that I put on the distributor to test well now theres no spark so I can't even test that theory.
AeroCoupe
6,256
4,341
183
Claremore, OK
Friday at 9:57 PM
  • Friday at 9:57 PM
Have you checked for codes? Even if the CEL is not illuminated there can be codes.
Is the car bone stock or does it have some mods like an MSD?
djj62478
51
Nj
Friday at 10:18 PM
  • Friday at 10:18 PM
Yes, there were no codes pertaining to this issue. Canister purge, EGR, and something else minor.
Mcmahst
5 Year Member
Jan 19, 2021
712
288
83
Laguna Woods CA, fort Mohave AZ
Friday at 10:26 PM
  • Friday at 10:26 PM
Can you post the data from your TFI testing?
djj62478
51
Nj
Friday at 10:28 PM
  • Friday at 10:28 PM
I dont remember off the top of my head, I followed a YouTube video. I can check again tomorrow and report back.
Reactions: Mcmahst and DadLife0724
nickyb
I gotta say i never painted my nuts, Never Ever
3,074
1,685
163
nevada
Saturday at 10:22 AM
  • Saturday at 10:22 AM
Check the ignition switch on the column, it could be coming apart and loose enough to cause havoc.
Reactions: Mindseye007, Mcmahst, General karthief and 1 other person
djj62478
51
Nj
Monday at 4:25 PM
  • Monday at 4:25 PM
So here's where I'm at. I tested everything I can think of. Grounds, coil is new and tested good as well as the old one, 3 different used tfi's which ask tested good, 2 used distributors. Restabbed the distribution multiple times. Finally I put on the original distributor and got a new cap and rotor, I got spark off the coil and off the number 6 plug after plugging the coil back in to the cap. Thought I was good to go. Well I go to start it and it doesn't start again, I was finally able to get it started by keeping my foot on the gas pedal to the floor and then working the throttle to keep it alive. When I tried to let it idle the rpms were super low and the tach would sporadically jump around until the car stalled, unless I started working the throttle to keep it alive. It also is not revving cleanly. I'm at by wits end and don't know where to turn next, I'm guessing computer? I know I'm using old parts to try this stuff I just hate to go and buy a new distributor for it not to work, a new TFI, then a new computer, new ignition switch, I just don't want to spend all that money to throw new parts at it when it could be something I'm overlooking. And honestly it all started when the car was still running fine but the tachometer started jerking up and down to the point it would cause it to stall sometimes, but even with that happening you were still able to drive the car, then it just got progressively worse
Admin Dude
Jan 4, 1985
43,578
21,742
234
Box behind Walmart
Monday at 4:43 PM
  • Monday at 4:43 PM
You seem pretty able to do your own troubleshooting so I'm going to put this here:
Thread 'Help me create the "Surging Idle Checklist"'
Apr 10, 2005
Updated 05 July 2022 to add rough idle when cold and smooth idle when up to normal operating temperature. See the EGR tech information, section #15 for more help.
Many of you are familiar with the "Cranks OK, but No Start Checklist for Fuel Injected Mustangs" checklist and the No Crank Checklist. They are very effective in finding and eliminating the problems by use of a systematic process that checks and eliminates possible causes. This idle problem checklist will use the same troubleshooting strategy and methodology.
By the term surging idle, I mean an idle that...
  • jrichker
  • 1986 1993 86-93 check engine light code 67 cranks ok dump codes eec-iv mustang no start
  • Forum: Fox 5.0 Mustang Tech
I see there's been some part swapping so, assume nothing and go step-by-step. Ask questions if you get stuck.
One of our members recently put the [No Start] checklist into pdf form.
You will find that here: https://stangnet.com/mustang-forums...stangs-model-years-1986-1995-pdf-version.112/
It's printable so, easy to take out with you if you prefer that over a phone or laptop.
AeroCoupe
6,256
4,341
183
Claremore, OK
Monday at 6:55 PM
  • Monday at 6:55 PM
I would also start looking for a known good ECU that you can try but run through the list first.
djj62478
51
Nj
Yesterday at 4:18 PM
#10
  • Yesterday at 4:18 PM
  • #10
Just tried a good ecu still no luck. It will sometimes start when cold and run for maybe 3 mins to 5 mins then won't restart or it will try but your foot has to be too the floor. I checked for spark again after installing the new computer with no luck, and again I'm getting spark off of the coil it seems but when I pull a spark plug off of the cylinder and try it grounded I usually only get one spark then nothing or very weak spark
Mcmahst
5 Year Member
Jan 19, 2021
712
288
83
Yesterday at 9:34 PM
#11
  • Yesterday at 9:34 PM
  • #11
I think the checklist is your best chance for discovering the issue. But, it seems the issue is heat related. Those electrical connectors expand under a heat load, making anything that is just making it work, not work. For what it’s worth, I would pull apart every single connector under the hood even remotely connected to the ECU and check each pin, expanding the male pins and tightening the female pins. And I would clean each, and apply dia electric grease to each. Now, that may not fix it, but it will be of value going forward. Good luck; I hope you find the problem.
djj62478
51
Nj
Today at 5:54 AM
#12
  • Today at 5:54 AM
  • #12
I also forgot to mention it I think I did that my little fuel pressure gauge that's attached to the fpr is dropping pressure. For instance with key on only I can hear the pump the pressure jumps to about 30 or so the immediately drops to 0. Is that normal or would this be part of the issue
Reactions: Mcmahst
AeroCoupe
6,256
4,341
183
Claremore, OK
Today at 11:25 AM
#13
  • Today at 11:25 AM
  • #13
Ha ha ha!!! Yeah, that’s a problem. Have you checked to see if there is any fuel in the vacuum line attached to the FPR? Is the FPR a stock unit or aftermarket? I’d the fuel pump stock?
Reactions: Noobz347 and Mcmahst
nickyb
3,074
1,685
163
nevada
Today at 12:27 PM
#14
  • Today at 12:27 PM
  • #14
Did you check the ignition switch? Go under the column and make sure its tight and secure, a new one is only $20 bucks. Or just use a zip tie.
You gotta rule out one thing at a time,I know its fusterating as I've gone threw it.
djj62478
51
Nj
Today at 12:40 PM
#15
  • Today at 12:40 PM
  • #15
Yes on checked the regulator vacuum line for fuel and it's dry, it's an accufab adjustable fuel pressure regulator with a intake 255 l per hour fuel pump that's brand new. Nickyb I replaced that ignition switch a while ago before I even got the car running because it was cracked but I know there was a metal clip or retainer that it came with it and never went on, so maybe that's the problem maybe that thing holds it in place and it worked it's way loose? Will that switch even cause the issues I'm having or just a complete no start?
nickyb
3,074
1,685
163
nevada
Today at 1:09 PM
#16
  • Today at 1:09 PM
  • #16
It caused me intermittent problems
Admin Dude
Jan 4, 1985
43,578
21,742
234
Box behind Walmart
Today at 1:11 PM
#17
  • Today at 1:11 PM
  • #17
I don't know how a faulty ignition switch would cause the pump to prime to pressure then fall off.
That's an issue that needs to be addressed.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
1990 Mustang with no-start condition - Fixed and how-to
  • TTSaleen
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TTSaleen
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
