ok i just did a v8 swap on a 90 4cyl mustang, i have 12v at all the injectors, fuel pressure of 40 psi and pump primes when key is engaged, hego ground on back of engine is hooked up, ground by starter solenoid is hooked, and computer ground is hooked up. my tps only gives a reading of .02 V and cycles up to 1v when i go full throttle. what could be the problem im loosing my mind trying to figure it out???
