90mm Lightning MAF
  • Thread starter Thread starter 94indy
  • Start date Start date Feb 13, 2006
94indy
33
hattiesburg
Feb 13, 2006
  • Feb 13, 2006
What needs to be done in order to use one on a mustang
C
criticman
723
Rome, GA
Feb 13, 2006
  • Feb 13, 2006
I have read that a pigtail from the 4.6 model MAF sensors will allow this to work, but in another thread Rick91GT pointed out that these sensors are OBDII and are likely not understood by the stock ECU.
just4bob50
504
Pa.
Feb 13, 2006
  • Feb 13, 2006
The lightning MAF will not work without haveing a way for the factory ECU to reconize it. When I bought mine I new I was going with the SCT chip and tune and that the tuner only had to set it up in the program. I was able to drive the car about 30-40 miles to the tuner and it drove fine on the highway at 2000 rpms but wouldnt idle for crap. Once the tuner put the chip in the started up and idled smoothly at 800 rpms. There are some hand held programers that you can buy that you can set up for the 90mm MAF, but if your going to have a tuner set the car up its probrably easier to let them do it.
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
D
Transceiver Ring
  • dtarang
  • Aug 22, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 22, 2026
dtarang
D
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
351W/5.8 EFI intake manifolds fading away...
  • Ryno5150
  • Jan 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
nickyb
