Not sure where the other guy got his info. The 91-93 fenders are different. The only difference is the wheel well opening. The openings were made bigger to accomodate larger wheel and tire packages. They bolt on the same way they did from 79 on, so you should have no trouble hanging them other than the usual alignment issues. If they don't have the side mouldings, you'll need to get ones for 91-93 cars as they're shorter in length because of the larger wheel opening.
