91 Ford Mustang coupe with 04 mach 1 engine 03 cobra irs and interior
lemanz
Check this out...
91 mustang coupe
04 mach 1 engine and trans,
03 cobra IRS
mach 1 and 03 cobra interior
GOT TO BE THE SWEETEST FOX BODYS I HAVE SEEN IN A WHILE
How many hours you think this took?
I bet a TON
full details HERE-->
http://www.hihpracing.com/hihp/viewthread.php?tid=175&page=1#pid865
Saw that on MPS salvage. Kinda looks "rushed" like the cut some corners.... The price is WAY HIGH too.... $19,000.....
i saw the car in person and was pretty blown away personally.
what corners do you see cut in the pics?
look under the hood... all wiring... mach 1
STOCK ECU with no engine codes... mach 1
the cooling... radiator and fans.. and resevoir.. mach 1
front suspension, k member, steering, hydroboost brakes, all mach 1
underhood painted and cleared
dash harness was a mach 1 modded to work with stock AC controls..headlight switches and cluster dimmer..
door harnesses mach 1
transmission tunnel was cut out and a mach one tunnel welded in for shifter fitment
fuel system? yep mach 1
think about how much time that took?
everywhere io look it seems they took the LONG cut.... far from short cut or "rushed"
id entertain your opinion though.. if you could point towards some short cuts .. from the pics..
i heard the reserve is considerably less than 19k
im sure they just stuck that number on it.
I dont think they are on fire to sell it.
Its pretty much one of a kind.. that i know of.
thats just my opinion.
well they shoved the newer cluster behind there and the trim plate around the shifter looks horrible in person. Interior is nice, but id yank the irs and put a sra back under it.
I saw the car at ffw in bristol its ok and id rock it but id prolly put the newer dash in it instead.
