Hi for anyone who knows. The top hole of my timing cover is stripped i was thinking heli coil or If i could drill all the way thru to just put a nut and bolt? And if i could would any metal shavings get inside the water pump?
I had that helicoil kit posted above and broke it the first time I used it. Very cheaply made. I did get it to work though for a rocker arm bolt hole in my aluminum heads...
Your comment noted and appreciated: NAPA may have a better,but more expensive helicoil kti.
Scratch that thought....it has the same cheap plastic insertion tool.
