92 5.0 Vortech Mustang No Start Condition!
Andrew Larsen
25
Hello, im having an issue with starting my 1992 5.0 Vortech Supercharged Mustang.
I was idling in a parking spot today and it stalled randomly. This is no strange occurrence to me as I have a lumpy cam, a supercharger and a untuned 5.0.
As I went to restart the car I couldn't hear the fuel pump priming and the motor continuously cranked without starting.
I also noticed my check engine light was dimly lit.
I came back later to try again. The pump started priming but ran continuously and wouldn't shut off. Where before it would usually stop priming after 3-5 seconds.
I can also hear a hissing sound by my injector rail. Don't smell or see any fuel. Not sure if that is normal or was there before or not.
My fuel pressure gauge which is attached to my FPR reads at 40-44 psi now with the pump on. (Walbro 255 LPH pump). The car still wouldn't start.
I next confirmed I had spark with a screw driver in the spark plug wire.
I had the car towed my house. I went to the parts store and bought a new fuel pump relay. Installed the relay into the fuel pump relay switch in the passenger fender well. Still no start.
I put a voltmeter on an injector harness and confirmed 12 volts at the harness with the key on.
I removed the EEC/A9L and opened it and found no corrosion or water damage.
Next im thinking of inspecting the spark plugs, replacing EEC relay, injector harness pulse test, and spraying starter fluid into intake to see if it will fire.
Appreciate any input or suggestions on what the problem might be,
Thank you!
Best info I can offer you,isn't even mine lol @jrichker has built a trouble shooting checklist,that is somewhat overwhelming but very informative and should get you up and running again..
since I ping the heck outta him for his checklists -I'll go a step farther and quote it in the next post,that way he can just answer questions you may have lol
MSD means "May Suddenly Die"
There are more posts with problems with MSD than any other single manufacturer.
The stock ignition is good to 400+ HP unless you have pressurized induction or NO2.
Put the stock ignition back in and see if the fixes your problem.
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 15-Sep-2014 to add temporarily bypassing the MSD box if it is present.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp [fuse
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
Were you plugs wet?
Run the codes to see if something popped up.
Did some more testing today.
I confirmed I had spark with the first test mentioned in that checklist.
I pulled out a spark plug after cranking for 8 seconds or so. The spark plug looked good and was completely dry and did not smell like fuel.
I used a noid light test on my injector harness and found that the light bulb was not lighting up while cranking.
I sprayed starter fluid into my intake and cranked her over. She fired up and was running for a short moment.
So I think im looking at an injector problem.
Any input?
Just for sake of memory, here's the checklist...
D.) Coil
Wiring Diagrams:
B.) Distributor cap
C.) Rotor
Two reasons:
Reactions: General karthief
Just for sake of memory, here's the checklist....
Still don't have it running.
1. I have spark at the coil wire and the spark plug wires.
2. plugs are dry after cranking and look normal
3. fuel pump is on and I have 44 psi of fuel pressure (pump doesn't shut off like its suppose too)
4. starter fluid will start the engine
5. I have 12 volts at injector harness
6. 1.6 volts at TPS
7. Pushing the pedal to the floor or any throttle position while cranking didn't work
8. I cleaned EEC ground by the battery and inside the passenger floor board kick panel.
9. injectors failed the injector noid test.
So what should I do next? Are these all the possible failures? And how can I test each possible failure?
1. ECM/ECU/EEC?
2. EEC relay?
3. PIP
4. TFI
I really appreciate any help.
I just bought an ECC from autozone. Cardone 78-4352. Very spendy but they had it in stock. Shipped to my home in two days.
I scratched some of the green fuzz on my A9L reinstalled it and now the fuel pump doesn't turn on. Jumping the Fuel Pump wire turns on the pump though. I tried starting the car with the FP jumped but wouldn't start because injectors arnt firing still.
My self test connections for CELs arn't flashing CEL codes when jumped...
So im basically having two problems. My fuel pump wont turn on and injectors arn't firing. Do you think both these can be related to the computer failing?
Any advice is appreciated. I am a bit overwhelmed and really hoping the new ECC fixes my problem. :doh:
I believe that is possible. Keep in mind that I am not as experienced as most on here but everything as far as the engine operation is contingent on info thru this shiny little box and if it can't processes said info than, well unpleasant things happen, or it just will not start.
Hopefully I sound smarter than I really am.
I did stay at a holiday inn express once.
@Andrew Larsen
There are two problems that may not have the same root cause.
1.) No flash when you dump codes. - either the computer has failed or the signal ground inside the computer has failed.
Computer will not go into diagnostic mode on 91-95 model 5.0 Mustangs.
Revised 7-June-2014 to change resistance figures to wiring checks
How it is supposed to work:
The grey/red wire (pin 46) is signal ground for the computer. It provides a dedicated ground for the EGR, Baro, ACT, ECT, & TPS sensors as well as the ground to put the computer into self-test mode. As long as you are successful dumping the codes by using the gray/red wire on the diagnostic connector for the ground when dumping, the computer’s internal ground on pin 46 is good.
If this ground is bad, none of the sensors mentioned will work properly. That will severely affect the car's performance. You will have hard starting, low power and drivability problems. Since it is a dedicated ground, it passes through the computer on its way to the computer main power ground that terminates at the battery pigtail ground. It should read less than 1 ohm when measured from anyplace on the engine harness with the battery pigtail ground as the other reference point for the ohmmeter probe.
What sometimes happens is that the test connector grey/red wire gets jumpered to power which either burns up the wiring or burns the trace off the pc board inside the computer. That trace connects pins 46 to pins 40 & 60.
The STI (Self Test Input ) is jumpered to ground to put the computer into test mode. Jumpering it to power can produce unknown results, including damage to the computer. The ohm test simply verifies that there are no breaks in the wiring between the test connector and the computer input.
How to test the wiring :
With the power off, measure the resistance between the computer test ground (grey/red wire) on the self- test connector and battery ground. You should see less than 1 ohm.
attachment.php
If that check fails, remove the passenger side kick panel and disconnect the computer connector. There is a 10 MM bolt that holds it in place. Measure the resistance between the grey/red wire and pin 46 on the computer wiring connector: it should be less than 1 ohm. More than 1 ohm is a wiring problem. If it reads 1 ohm or less, then the computer is suspect. On the computer, measure the resistance between pin 46 and pins 40 & 60: it should be less than 1 ohm. More than that and the computer’s internal ground has failed, and the computer needs to be repaired or replaced.
See http://www.stangnet.com/mustang-forums/749974-computer-issue.html#post7490537 for Joel5.0’s fix for the computer internal signal ground.
If the first ground check was good, there are other wires to check. Measure the resistance between the STI computer self-test connector (red/white wire) and pin 48 on the computer main connector: it should be less than 1.5 ohms. More than 1 ohms is a wiring problem
The following is a view from the computer side of the computer wiring connector: it is for an A9L, A9P computer.
eec-iv-computer-connector-for-5-0-mustang-gif.88243
a9x-series-computer-connector-wire-side-view-gif.71316
Check out the diagram and notice all the places the grey/red wire goes. Almost every sensor on the engine except the MAF is connected to it.
91-93 5.0 Mustangs
salt-pepper-10-pin-connectors-65-jpg.68512
(website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine
2.) No pulse at the injector - failed computer or bad PIP sensor.
The PIP signal level needs to be above 6.5 volts to trigger the computer, but only needs to be 5.75 volts to trigger the TFI module. Hence with a weak PIP signal, you could get spark but no injector pulse. You will need an oscilloscope or graphing DVM to measure the output voltage since it is not a straight DC voltage.[/b]
@jrichker
Hey thank you for the response. Appreciate it man.
Autozone emailed me and said they didnt have any ecus in stock. So I bought a tested A9L on ebay. Arrives on the 21st.
I have a few questions about your last post. I want to try and eliminate any other possible problems other than the ECU.
1. My fuel pump is still running continuously. Some times when I turn the key to the on position the fuel pump doesn't come on at all.
2. I have a dimly lit check engine light when I turn the key to on position.
3. No injector pulse with 11.6v to injector harness.
4. And im getting no codes. I got it to spit out a code 10 and 111 once one of the times when the fuel pump wouldnt come on. But its not working properly with a test light and jumper wire or a scanner.
1. I measure the resistance between the computer test ground (grey/red wire) on the self- test connector and battery ground. I measured sub 1 ohm.
2.I checked the ground pins (46,40,60) on my computer and they all were sub 1 ohm.
I tried to test the ohms on the STI and pin 48 on the computer harness. I used a long 14ga wire jumped from the STI to the inside of the car where my DDM probes could reach the harness and the STI probed wire. I didn't get a reading. So I think im doing something wrong here..?
I also attempted the same process for the grey/red wire and pin 46 and didn't get a reading either.
What do you think im doing wrong here?
Thank you for your input![/QUOTE]
