92 foxbody front disc brakess
92madfox
Santa rosa ca
So I have 94 sn95 spindles on my fox w small front discs. Want to upgrade to cobra calipers and 13 inch rotors. Will I have to change my master cylinder for proper function or will the stock one work ok? I'm told that I definitely have to upgrade to add rear discs. Any advise out there?
  • Sponsors(?)
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,265
9,572
224
Massachusetts
I assume you are running rear drums?
Then no, you do not have to change your MC because an MC suited for your setup doesn't exist. The stock one is as close as you'll get so you need to live with the pedal feel that you get.
Now, if you want to get pedal feel and brake bias more in line to what is proper, then you should add disk brakes. Plenty of guy do drive around with cobra fronts and rear drums fine and like it
Thread starter Similar threads Forum Replies Date
B Fox 87 GT rust repair 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
Steel1 Suspension Torque Specs For Foxbody Front Suspnsion ? Fox 5.0 Mustang Tech 4
1989LXFOX Knocking At Passenger Side Front Tire Fox 5.0 Mustang Tech 8
9 Brakes Sti Brembo On A Fox Fox 5.0 Mustang Tech 2
S Will A Fox Front Frame Rail Fit A 95 Gt 1994 - 1995 Specific Tech 4
B 87-93 foxbody mustang Saleen front air dam for sale Interior Exterior Parts 1
bigmike73 sn95 front seats in foxbody 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
L Foxbody front wheel fitment Fox 5.0 Mustang Tech 2
A '92 foxbody and 17*9s on front question Fox 5.0 Mustang Tech 17
A 460 foxbody front suspension Classic Mustang Specific Tech 3
Boostedpimp Fox 93 Foxbody Coupe value 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
D Idles Fine, Rev engine High Manually, engine comes down and dies. 2.3L (N/A & Turbo) Tech 0
J Brakes Foxbody brake Booster Fox 5.0 Mustang Tech 0
T Wing and luggage rack 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
D stock rocker arms breaking The Welcome Wagon 2
A Used Foxbody Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
O Digital Tuning Anyone know this Superchip? Fox 5.0 Mustang Tech 3
D Foxbody torque box reinforcements 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
M Electrical 1989 mustang 5.0 runs rich and stumbles in closed loop Fox 5.0 Mustang Tech 10
W New guy, 1989 foxbody The Welcome Wagon 1
S 1993 Mustang 2.3 L Automatic A4LD Transmission - Help 2.3L (N/A & Turbo) Tech 2
M Engine 87 Foxbody Hesitation at High RPMs Fox 5.0 Mustang Tech 15
D 1989 Dash Harness Problems Fox 5.0 Mustang Tech 2
F Advice needed for Foxbody build 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 28
T 93 convertible torque box reinforcements 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
B [Project Car] 1986 5.0 V8 Foxbody Mustang Starting Issue Fox 5.0 Mustang Tech 8
S 391 swap into foxbody 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 24
5 Powersteering Pump replacement gone wrong Fox 5.0 Mustang Tech 15
F Brakes Hydro boost foxbody Fox 5.0 Mustang Tech 8
8 Electric fan problem Fox 5.0 Mustang Tech 2
Waz900 Brakes Foxbody SN95 Booster install Question Fox 5.0 Mustang Tech 3
A Car starts but dies Fox 5.0 Mustang Tech 2
8 Coolant leak Fox 5.0 Mustang Tech 4
spiegs throttle cable removal and install Fox 5.0 Mustang Tech 8
C Engine Gray smoke from exhaust. Smells like gas. Fox 5.0 Mustang Tech 15
1hot87gt Love my FoxBody 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
K New Member introduction 1990 Foxbody Hatchback The Welcome Wagon 1
C Foxbody with no start issues Fox 5.0 Mustang Tech 5
E Best tires for 88 Foxbody GT? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
K Is my foxbody cammed? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
White85fox New from Idaho The Welcome Wagon 3
Foxslider SOLD WTB: 87-93 stock foxbody axle out of 8.8. Drivetrain Parts 0
M 93 foxbody 347 stroker megasquirt 2 pnp initial timing set up?? advice Digital Self-tuning Forum 6
S Fuel Explorer Throttle Body.....What Years Will Work On Foxbody Fox 5.0 Mustang Tech 5
12Pack WTB/Trade Wtb foxbody, FL Fox Body Mustangs For Sale (1979-93) 0
S Motor Mounts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
S Old Foxbody owner looking to own again. The Welcome Wagon 4
K What's it Worth? 87 Fox GT What is it Worth?!?!? 11
T Exhaust Replacing cats with O/R x pipe and need a tuner Fox 5.0 Mustang Tech 6
mustangmccance Foxbody owner from Iowa The Welcome Wagon 14
