92 T-BIRD PARTS SWAP INTO A STANG?
  • Thread starter Thread starter Nemesis67
  • Start date Start date Mar 29, 2007
N
Nemesis67
146
Las Vegas, NV
Mar 29, 2007
  • Mar 29, 2007
Anyone know what parts can be swapped over to a Classic Mustang? Then again has anyone ever tried? I have the possibility to pick up a 92 T-Bird for cheap and I just want to know. The motor and tranny will most likely transfer, but what about brakes and front mcpherson strut suspension and brakes?
gunmetal5.0
144
Chico, CA
Mar 29, 2007
  • Mar 29, 2007
More specific information about each car would probably yield better answers for you.
N
Nemesis67
146
Las Vegas, NV
Mar 29, 2007
  • Mar 29, 2007
The T-bird has a EFI 302 with an AODE. The mustang is a 67 Fastback, originally a 289 with a C4.
gunmetal5.0
144
Chico, CA
Mar 29, 2007
  • Mar 29, 2007
I would say if you made the new motor and trans carbed it could be a very direct and simple install. Things I could foresee possibly needing is a different length driveshaft and/or yoke. If you want to keep the EFI on the new engine you will need to transfer the entire harness over and wire in the switches or get an aftermarket harness. You would have to update fuel pump and you would need to plumb a return line. Likely the easiest would be to simply take the intake off of the current engine and put that onto the new long block.
N
Nemesis67
146
Las Vegas, NV
Mar 29, 2007
  • Mar 29, 2007
I'm looking for a donor car to use the harness and computer. I plan on using a 94 351W fuel injected and stroked. But I also want to use new suspension, if the mcpherson strut, spindles and brakes swap over with little effort. I'd also take into consideration swapping in the rear end too. I know that wouldn't be a bolt in job, but I plan on using a different rear suspension anyway. Preferrably a coil over unit. But that all depends on whether the 8.8 will stand up to the abuse.
9
96 DOHC Cobra
542
Cerritos, CA
Mar 29, 2007
  • Mar 29, 2007
Forget the front suspension and brakes. Neither will work. The struts would require custom parts, and the brakes have a smaller (metric) bolt pattern. They're 5 X 4.25" compared to the Mustang's 5 X 4.50" bolt pattern.
N
Nemesis67
146
Las Vegas, NV
Mar 30, 2007
  • Mar 30, 2007
Well that's good news. Not going to use this one. Thanks?
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
L
SN95 Interior / Exterior Color Combinations - were some not possible?
  • lparsons42
  • Aug 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 2, 2025
Mustang5L5
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
