Electrical 93 5.0 turns over - no start
1993 5.0 setup
Turns over doesnt start
Will start if fuel or starting fluid is sprayed into intake, spark is good
35lbs on fuel rail, fuel pump runs
Fuel injectors are not pulsing, confirmed with noid light
Fuel injectors have battery voltage on red side 11.8v
No fuel entering cylinders from injectors
Replaced ECM, no change.
Thanks for any help.
Just based on your problem description and the fact it will start with spray fluid I would say to replace the PIP in the distributor or replace the entire distributor, I have heard that quality units are few so maybe another member can suggest a brand.
Did you just get this stang or was it running fine and one day wouldn't start?
