Electrical '93 5.0 won't turn over when cold.
evintho
Nov 12, 2003
683
246
73
Santa Rosa, CA.
12.5v at the batt all the way to the fender solenoid. It had been running fine but suddenly, In the morning when I try to start it I get one click. I pop the hood and jump the fender solenoid from one terminal to the other, with the key on and it fires right up. Also, after I've driven it awhile and I shut it down, I try to restart it and it fires right up. I believe it's the original '93 solenoid. Does that sound like it's probably just a solenoid replacement, or could it be something else?
Everything, including the entire wiring harness is brand new or rebuilt.
For 1993 there are two solenoids. It's essentially a double-relay.
Take a jumper wire and jump the small upper terminal to the post with the batter connections and see if the car will crank doing that, vs bridging the two main terminals.
What i mean by that is touch your screwdriver from here to here and see if it cranks healthily. If it does, this may be an ignition switch issue
Just for reference the wiring diagram. The above relay would be labeled "starter relay"
That part has quite a few bad reviews. Multiple people had issues with the plastic cracking when they were tightening down the terminal nuts.
Here's a Motorcraft option (not saying it's better necessarily, but it does have fewer bad reviews, and more good reviews... for what that's worth!)....
I had a Motorcraft fail shortly after buying. The standard has been in the car for a few years now so that’s why I recommended it.
It’s a crap shoot anymore.
I did just that. Jumped from the small stud to batt stud, w/key on and it fired right up. Ignition switch is a new Standard Products unit and all wiring is new.
