93 Cobra 5 Lug Conversion..i Know I Know Just Read On
Justin Medeiros
Hey guys I'm new to this sight and have a 93 cobra clone with a 93 cobra rear end in it doing 5 lug swap trying to do the swap a little different because I have access to pretty much any machining equipment I could possibly need. I was planning on redrilling my 93 cobra axles to 5 lug so I can retain the stock brakes, and I'm looking for a 5 lug rear rotor that has fox body axle center bore. Any ideas? My plan b was to use 94-95 axles (should be the same 3/4" per side longer length than normal fox, but want to use the stock 93 cobra rear Vargas calipers but don't know first off if that will work and secondly if there's a rotor out there that will work. I'm using 99 cobra wheels 17 x 8 with 30 mm offset. Any help is greatly appreciated
