drewzx3 said:If I buy an intake from a 93 cobra will I just have to get the adapter or is there other things you have to do to use the intake?
VibrantRedGT said:18, what needs to be drilled? Simply bolt on the 94-95 Elbow is all that's needed for it to work on our cars. The internal EGR hole for the FOX style just needs a 3/4 cap. The elbow is plug and play. Just about all aftermarket intakes for 302 based blocks are listed from 86-95.
18mustangs said:The bolt holes on the edapter and the intake don't line up..they're slightly off.
RFMustangGT said:I bought the edelbrock elbow and it lined up just fine. only thing I had to drill was the lower right hole just to make the bolt work and easier to get it to tighten.
18mustangs said:Perhaps it's just coincidence then because I had the Edelbrock adapter and the holes were slightly off compared to my 93 cobra. If you got yours to work I'm happy. Either way, after researching all of the possibilities of using the elbow it was a toss up on the amount of work and fabrication that I'd have to do between using the elbow and doing the Fox TB conversion. I liked the way the Fox setup looked (and I hate the SN95 elbow, both adapter and stock) so I went Fox and never regretted it. Plus, I could run EGR again with the Fox setup as my BBK LTs (first gen SN95 LTs) didn't have the EGR bung.
Tim
RFMustangGT said:after me destorying my nice fox valve covers I've even started to consider the fox TB swap. I had these nice fox valve cover al slicked up and painted a nice gloss black and teh stupid filler neck wouldn't fit. apartently the fox neck is different than the 94-95. after some loving with a sawzall, another ainnt job, a rubber gromet, and a PCV valve, it worked.
