93 Engine Mounts In Pre-93 Chassis
jAEded
418
26
39
Cali
Background: Chassis is a 1991 otherwise everything is from a 1993. K-member is from the 1991 and the car was originally a automatic converted over to a 5-speed.
I've been having problems trying to get a pair of 93 engine mounts installed. I destroyed a set of mounts already.
The engine doesn't sit down on the k-member properly and I thought I could force it by tightening down the mounts. It twisted one of them and cocked the engine at a angle.
I bought another brand of engine mounts but I'm reluctant to try and install them. The local autoparts store lists different mounts for a 1991 and I'm not sure if I should just try those instead while I can still return the ones for the 1993?
My understanding is that the 93 mounts should fit in previous years? I thought all it does is slightly lower the engine over the other mounts?
Any help or knowledge is appreciated.
I thought I was losing my mind.
I bought the Anchor Brand from Summit. OEM rubber. It turns out the locating pin was missing from the driver side mount. I bought a set of Duralast engine mounts today for a 93 from a local auto parts store. From outward appearances they look the same as the Anchor Brand, but the pin was in both mounts, and now the problem is fixed.
