- Mar 22, 2007
- 2
- 0
- 1
I bought the prothane total kit and have replaced all the bushings throughout the whole car...rear end went kinda smooth and everything else is a go but the front end. I am having trouble getting the springs back in place. I also am having trouble with the shock nut on the caster plate. I have tried both spring compressors that you can rent from autozone and neither have helped. I have done a search and it seems like everyone leaves the shocks connected and undo the lower control arm but even installing them the first time was a PITA because the prothane bushings were so tight and I had to fight with the bolts for 2 hours to get them even slid in. I couldn't imagine trying to do it fighting a spring too and messing with two jacks. Im at a loss. Also I got one shock off on the drivers side and the passanger side is spinning with a snap on electric impact. I have tried a wrench and screw driver but It will not hold the shaft tight enough....any ideas or thoughts would be appreciated.
