9 93BlackBeast Member Dec 9, 2002 81 0 6 Raymore, Mo. May 10, 2005 #1 May 10, 2005 #1 When I am driving and come to a stop, let's say at a red light, the rpm's jump and idle like at 1500-2000 rpm's. It does not happen all the time, just occasionally. Anyone know what the problem could be?
I_AM_CANADIAN Member Mar 30, 2005 189 0 16 B.C. May 10, 2005 #2 May 10, 2005 #2 does it only happen when the engine is cold?
Henceforward The Avatar Master Founding Member Jul 17, 2001 485 0 0 May 10, 2005 #3 May 10, 2005 #3 Pull of the IAC and clean it out real good with carb cleaner. Set the TPS voltage to .90-.99 If your AC is off, turn it on, and that will drop the idle by 100-200 Rpms...
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 May 11, 2005 #4 May 11, 2005 #4 yeah, since it is intermittant, the IAC probably has a hiccup. see if you can notice any other rhyme or reason that it will hang when it does. good luck.
