'93 LX 5.0
  • Thread starter Thread starter '93 stanger
  • Start date Start date Dec 3, 2007
9
'93 stanger
  • Dec 3, 2007
hey guys...I'm not really experienced with cars, engines, and all that technical stuff for cars...but I really love my mustang. I was wondering if you guys could make any suggestions on how I could get starting on making my stang more special...like performance parts-wise
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Dec 3, 2007
  • Dec 3, 2007
Gears and nitrous is always a good start.
cervinistang
11
Dearborn, Michigan
Dec 3, 2007
  • Dec 3, 2007
any pictures?
depending on what you have under the hood i can give a few suggestions.
cervinistang
11
Dearborn, Michigan
Dec 3, 2007
  • Dec 3, 2007
cervinistang said:
any pictures?
if you have the stock intake. your gonna next to install cold air.. maybe in the fender well.
9
'93 stanger
  • Dec 3, 2007
its all stock
RsStanG1987
569
9
79
Dupont PA
Dec 3, 2007
  • Dec 3, 2007
No he wont. If his car has the stock air silencer he needs to remove it and get a k&n filter.. No need to spend $140 on something a $50 part will do..
RsStanG1987
569
9
79
Dupont PA
Dec 3, 2007
  • Dec 3, 2007
Ill rundown what to get. Full exauhst -headers, h-pipe, catback.. Gears 3:73's should do.. K&n filter.. Decent cap rotor and wires. Short throw shifter, and some under drive pullies. Thata the basics before getting into the engine itself. Id also advise on getting a set of subframe connectors.. If a 5 speed id get a good clutch and an aluminum quadrant with a firewall adjuster..
9
'93 stanger
  • Dec 3, 2007
so i found this product online for a k&n filter...is that something i would be looking for?
why not get cold air intake again?
hamonkeiser
290
Lancaster, PA
Dec 3, 2007
  • Dec 3, 2007
Cold air kits are fine but are mostly for looks. You'll still get hot air from the enginge compartment heating the cold air pipe which defeats the purpose. You'll get the same airflow gains as the cold air kit by just removing your air silencer (mounted in the fender) & replacing your factory airfilter with a replacment panel filter from K&N.
If you like the look of the cold air system, that's fine. It won't hurt anything but save you self the money & just get a cheap one off of ebay.
hamonkeiser
290
Lancaster, PA
Dec 3, 2007
#10
  • Dec 3, 2007
  • #10
How much are you looking to spend?
9
'93 stanger
#11
  • Dec 3, 2007
  • #11
oh woops...forgot to put the link in
http://www.dallasmustang.com/page/products.php?product=8096
9
'93 stanger
#12
  • Dec 3, 2007
  • #12
well this would be all cumulative....i wouldnt pay for this all at once...but at least maybe a couple grand to start, not sure if i would put any more into it as of now
T1 3VOM
Maryland
Dec 3, 2007
#13
  • Dec 3, 2007
  • #13
It's been discussed several times in the Tech section. Here's one thread I found real quick:
http://forums.stangnet.com/showthread.php?t=725336
Not a perfect match to what you're looking for, but I think you'll find some good info there.
hamonkeiser
290
Lancaster, PA
Dec 3, 2007
#14
  • Dec 3, 2007
  • #14
Yep, that's the filter you would want. Is the car going to be a daily driver or a weekend toy?
There are a lot of options to consider depending on how you intend to use the car.
9
'93 stanger
#15
  • Dec 3, 2007
  • #15
daily driver
Flavadave4
1,044
21
49
Utica, NY
Dec 3, 2007
#16
  • Dec 3, 2007
  • #16
Show us some pics and I am sure everyone will put in there $.02
...but its your car you should really have an idea and go from there, for some pointers search for the nicest fox thread and you'll get some ideas of what looks goo to YOU and what YOU like.
Good luck man...
cenok is family
1,409
69
79
Norman, Ok
Dec 3, 2007
#17
  • Dec 3, 2007
  • #17
because the stock intake IS a cold air kit. and the 90* bend right before the mass air meter on aftermarket cold air kits causes turbulence in the airflow and will give the sensor an off reading. you should definitely build up the suspension before breaking into the motor. Just like building a house, start with a good foundation. go with what RsStang said: full exhaust, (headers, midpipe, mufflers), a set of gears, subframes, control arms, shocks/struts and springs, if it's a 5spd get a shifter and an aluminum quadrant.
9
'93 stanger
#18
  • Dec 3, 2007
  • #18
yeah I have a 5 speed...so im curious to what the shifter and an aluminum quadrant will do...and why only for the 5 spd?
cenok is family
1,409
69
79
Norman, Ok
Dec 3, 2007
#19
  • Dec 3, 2007
  • #19
go with either a Pro 5.0 (www.pro50.com) or an MGW (www.mgwltd.com) shifter. both top quality, GREAT shifters. the shifter will give you shorter throws and shift stops. if you're slamming through gears without stops, you'll bend a shift fork inside the tranny. it also gives you a much more solid feel when shifting through the gears. the stock quadrant is made of plastic and will break over time, especially if you have an aftermarket clutch. replacing it with an aluminum piece is just preventative measures to keep you from being broke down on the side of the road, all because of a $50 piece of plastic. and more peace of mind knowing you can slam on the clutch without breaking the quadrant. and it's only if your car is 5spd because only a 5spd car uses a clutch quadrant and manual shifter. of course auto's have shifters, but it's not necessary to change it on a street car, just get a shift kit.
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Dec 3, 2007
#20
  • Dec 3, 2007
  • #20
with mine being a DD as well im going with the suspenion a spect first.
C
Fox 1993 LX 2.3 help identifying this
  • Coyoteswap93
  • Jul 17, 2026
AeroCoupe
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
