Car idles, runs, & drives fine. After 45mins to 1hr of driving around Freeway/In Town the vehicle will die an not start back up right away. I will have to wait about 5-20mins before it fires up again. Some times it has loss of power after coming to a stop, the speed gauge only will start to move up & down all crazy. this is when the car will sometimes turn die/off if I don't play with the gas pedal.
Car will not pass smog due to EVAP Leak.
For my 172, & 332 code. I checked & repaired all vaccum pressure hoses/lines, replaced EGR, replaced Canister Purge Valve, replaced Fuel Filter.
Fuel Pump is working. I will be doing a fuel pressure test, as well as Throttle Position Sensor. Before I replace the Items below, before dropping the gas tank to inspect.
I have NEW coming in the mail soon Fuel Filter, Fuel Pump, Fuel Injectors, Fuel Pressure Regulator, PCV, Gas Cap.
For my 222 code. I have took my ICM to get tested at O'Reilly's. Passed 2 times. Will be testing Coil Pack.
I have NEW coming in the mail soon Ignition Switch, 2 Coil Packs.
