93 mustang A/C HELP
  • Thread starter Thread starter stunna1212
  • Start date Start date Feb 8, 2010
stunna1212
  • Feb 8, 2010
hey guys, newb here, i have a 93 5.0 and im trying to recharge my a/c with r12...before i blow something up im trying to find where the low side is so i find the right fitting...my mustang is stock...if someone could help me out that would be great! maybe even a pic??? thanks in advance!!
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Feb 8, 2010
  • Feb 8, 2010
You really need to pull a vacuum first before recharging. If your system is low, it suggests a leak in which case putting more expensive R12 in will just cost you money because it will leak out again.
This is assuming you haven't done so, which you didn't clarify really.
stunna1212
  • Feb 8, 2010
i also will be pulling a vaccumm as well but i have used equipement with no insructions...do u know where the low port is?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Feb 8, 2010
  • Feb 8, 2010
Low port would either be the port on the compressor at the front, or on the accumulator bottle at the rear of the car on the firewall. Depends on the year which you have, but most have the port on the compressor.
The high side is the line behind the compressor right in front of the dist.
stunna1212
  • Feb 8, 2010
i have a 93...so its the port on the compressor itself? thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Feb 8, 2010
  • Feb 8, 2010
It's the only fitting physically on the compressor body itseld...Right on top, should be a black cap on it. Can't miss it
stunna1212
  • Feb 8, 2010
great, thanks for your help!!!
giddyup306
3,041
Feb 9, 2010
  • Feb 9, 2010
If he is low he HAS a leak. No ifs, ands, or buts. To recharge he doesn't need to pull a vacuum because sometimes the system leaks leak under pressure, other times under vacuum. R12 leaks something like 8x less than r134 because the molecules are so much bigger. With R12 you might have a one year leak, and this sort of work should really be left to professionals. I got my EPA 609 licence back in '03.
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Engine A/C QUESTION
  • Mindseye007
  • Jun 5, 2025
  • 2 3 4
3K
Fox 5.0 Mustang Tech Jun 22, 2026
nicholase
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
