SOLD 93 Silver coupe 331 Vortech YSI Cage Bear brakes for 03-04 Cobra
notchysi93
[/IMG]
93 Silver coupe 331 YSI Cage Bear brakes for 03-04 Cobra
well been thinking about this for a while and would like to see what i what it out there for trade for my Coupe that has a ton of money and time in it would like to do my coupe and cash for the right Cobra I am looking only for Sonic Blue or Silver 10 th Anv coupe cobra that are Built and make good power and streetable! Please guys only looking for an 03-04 cobra thanks for looking BEST WAY TO GET IN TOUCH WITH ME IS CALL TEXT 508-901-0213 OR EMAIL [email protected] or shoot me a P.M THANKS
motor: 331
Dart sportsman block
sfi approved balancer
scat forged 4340 crank
scat forged h beam rods
probe srs dish pistons
(rotating good to 1000hp)
anderson b451 renegade cam
t.e.a. renegade worked trickflow heads. these are the exact same heads that they run on the efi renegade cars that run mid 8's titanum valves, locks, and retainers. flow 325 at .550 intake and 226 at .550 exhaust.
t.e.a ported renegade holley systemax2 intake with poly heat spacer
comp pro mag 1.6 rockers
tfs harded push rods
bbk 75mm throttle body and spacer
canton 7qt pan
canton windage tray
f.m.s. high volume oil pump
edelebrock water pump
fluidyne aluminum radiator
centerforce sfi 50oz flywheel
fms aluminum valve covers chromed
fms mini torque starter
energy suspension motor
Valve covers sheet metal with dash 10 pungs with puke tank
trans:
brand new tko 600 all cryo treated will hold 800hp 800tq at wheels
brand new spec stage 3+ clutch
brand new pro 5.0 shifter
fms aluminum drive shaft
lakewood ds loop
energy suspension trans mount
rear:
8.8
fms 3:73 gears
energy suspension bushings in upper rear
eaton diff
31 spline moser axles
ta girdle
moser long studs
all welded tubes and ends
power adder:
vortech ysi belonged to chris van gilder last years efi renegade champion. fresh from vortech doesnt have 500 miles on it.
all custom blow thru set-up
front mount hellion air to air intercooler
tial 50mm blow off valve
asp custom 8.6 crank pulley 10 rib
reihcard racing 2.95 10 rib xgrip blower pulley
asp billet idler
anderson ford motorsports adjustable belt tensioner
AIS meth injection kit with adjustable controller(not on car but will come with)
suspension:
front
bbk springs
saleen sway bar
lakewood 70-30 struts
rear
wolfe racecraft double adjustable uppers
wolfe racecraft double adjustable lowers
bbk launch springs
lakewood 50/50 shocks
behind bars racecars floor plates
chassis:
bear big brakes which you know
10 point cage with swingouts
maxium motorsports subframe connectors
taylor battery relocation kit
lakewood line lock
corbeau front seats
18x10 fr500 rear
18x9 fr500 front
exhaust:
mac 1 3/4 long tubes
3inch kooks X-pipe
kooks Mufflers with turn downs
fuel system:
aero eliminator pump
aero filters
-10 feed
-6 return
aero boost ref regulator
russell y block with pressure gauge
behind bars race cars fuel rails
96lbs injectors
flip switch with street tune and race gas tune blow thru meter
aero sumped tank
aero billet top return to cool fuel
ignition system:
msd 6al
msd distributor
msd 3 step
taylor 10.4 wires
tuning:
gauges:
all auto meter silver faced
tach
water temp
boost
fuel
voltage
oil press
boost and fuel pressure are in autometer cage mounted gauge cups
oil water temp and volt are in autometer gauge cage in center vent
wideband is aem silver faced as well
