94 5.0 HELPPPP won’t run right
Mcfanny
Massachusetts
New here I’ve spent hours on this thread with so much info I’ve absorbed.
I recently purchased a half completed sn95. I put the car back together to the best of my ability.
Below are some new parts that have been installed on the car
New plugs. Wires. And distributor. (Stabbed and running at 10 deg timing with plug out ) new fuel injectors. Bosch 50s with matching pro m maf. New ccrm(car was missing this )
car came with manynew and used parts already installed. One being a throttle body iac and tps. I’ve plugged in every sensor that corresponded with the near by plugs.
New fuel pump. Filter and sock.
spun motor over and car wouldn’t idle. Adjusted timing many times with no improvements.
When switching to any gear the car will die out if I don’t have my foot on the throttle.
the current state the car is now in is it will not start without throttle. It will not rev over 2000rpm and there is a large amount of fuel in the oil.
looking for some advice on where I should start.
thanks, matt
What’s your fuel pressure at? What’s all done to the engine? A modified engine with the t4m0 eec is usually going to run like garbage if heavily modded.
So I had to manufacture my own fuel lines from fender well to rails. I don’t have a port to access fuel pressure any longer. Engine is stock lower end. Ported e7s to a Holley systemmax upper and lower. Stock cam. I have a full on3 system to install. Hence the fuel injectors and bigger pump. 340lph pump.
So short and sweet mainly stock.
