94-5 mass air the same as 89-93
94-5 mass air not the same as 89-93
i just went to the yard and bought a mass air meter from a 94 mustang and when i got home it is the same size as the stock one on my 89 gt so im kinda pissed that i wasted my time and money on this meter and the adapter so if anybody i looking for a meter to do a swap let me know. the yard may have given me the wrong meter so if someone has a pic of a stock 94-95 mass air meter post a pic or send one to [email protected]. thanks
was it a "pick-your-part" junkyard, or did they go and get the part for you.
if they got the part for you, and you asked for a 94+, they probably just got you a 93- mass air meter because they know it will work on a 94+. the 94+ should be a larger diameter though, so i think you got screwed.
89-93 MAF is slip connectors on both ends for the air duct. It has a 55 MM opening.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a $25-$35 flange adapter from Pro-M to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes.
Pro-M has revised their website lately, but here's what I found.
http://performancepartsmall.com/detail.asp?id=224 plastic adapter
http://performancepartsmall.com/detail.asp?id=223 metal adapter.
I got a metal one from Powered by Ford for $35 and tax. That was about a year ago.
Powered By Ford
1516 South Division Avenue
Orlando, FL 32805
Hours 0800-1800
Phone 407-843-3673
http://www.poweredbyford.com/
whitenblu89 said:
the one i bought has the slip fit on one side and th flange on the other and i even went out and bought the adapter. so now im stuck with both. the one they sold me is the same size that on my car stock.
Measure the MAF opening. At 25 mm per inch, 55 mm is about 2 3/16" - a little.
A 70 mm MAF would be a little less than 3", somewhere around 2 3/4"
