Expired 94-95 5.0
St33zyxSaleen
20
$2000
Hampton, Va
1994-1995 5.0 modded motor
Engine has less than 200 miles on it
Build list:
Lms Economy 5.0 short block
Ford Racing pump, pick up and pan
ARP oil drive shaft
Comp cam cobra cam oem
Gt 40 x turbo swirl heads
1.7 Ford Racing roller rockers
Ford Racing hydraulic lifters
Ford Racing hardened pushrods
Edlebrock RPM performer I intake
Edlebrock throttle body neck 70mm
1/2 intake spacer
Stock Throttle body
24Lbs/Hr Accel injectors
MSD coil
MSD distributor
Ford Racing chrome distributor hold down
MSD 8.5mm Spark plug wires
Motor craft plugs
Ford Racing timing cover
Ford Racing reverse flow water pump
Chrome smog pump delete
Chrome mustang embossed valve covers
PA performance high torque mini starter
Excedy Stage 1 Clutch Kit
New power steering pump lifetime warranty at autozone
ARP fasteners: heads oil pump and pickup, fly wheel timing cover, header bolts, lower intake to heads & water pump.
Steeda adjustable clutch cable
Bama 4 bank chip
Ecu for automatic and manual transmissions
