94-95 70 Mm Maf Question
  • Thread starter Thread starter BKM48198
  • Start date Start date Sep 12, 2014
First Prev 2 of 2
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
Sep 15, 2014
#21
  • Sep 15, 2014
  • #21
[QUproblem"BKM48198, post: 8861984, member: 139406"]Thanks, I'll check them out.[/QUOTE]
No problem bro
BKM48198
377
27
49
Ypsilanti, Michigan
Sep 15, 2014
#22
  • Sep 15, 2014
  • #22
No problem bro[/QUOTE]
I see the 130's do have just the 2 holes and the 95's have 4 together, that will make it easier to make sure I get the right one. I sold a set of Ford motorsport valve covers last night so I'll be getting an Alt. this weekend. I have seen that for the swap I will need a fuse in-line from the Alt., but I have seen posts saying I need a 125 to 135 amp fuse and other posts saying to use a 150amp fuse. What size is correct and best to use?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 16, 2014
#23
  • Sep 16, 2014
  • #23
I would go with a 135 amp fuse if you can find it. Otherwise, use a 125 amp fuse. Most fuses will carry a 25% overload for about 5 minutes without blowing.
BKM48198
377
27
49
Ypsilanti, Michigan
Sep 16, 2014
#24
  • Sep 16, 2014
  • #24
I noticed on a Ford Taurus they have a 175 amp fuse on them as OE, so while at the JY I will see if I can get a few of them, they only charge $0.15 each and they have plenty of Taurus to get them off if someone else hasn't beat me to them. I'm wondering about the 4 gauge wire, is the OE wire on a Taurus 4 gauge? If not the cable from the solenoid to starter on a 5.0 ( F-150/ Crown Vic/ Grand Marquis) should be long enough so I might try to get one of those. Napa has the 125amp fuses for $6.99, haven't found a 135 amp yet.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 16, 2014
#25
  • Sep 16, 2014
  • #25
Get the NAPA 125 Amp fuse and be done with it.
It is much better to use a smaller fuse on a wire than over fuse it. There is less chance of going damage to the wire and the circuit the fuse protects.
Reactions: 7991LXnSHO
BKM48198
377
27
49
Ypsilanti, Michigan
Sep 16, 2014
#26
  • Sep 16, 2014
  • #26
I will get one from Napa, just going to get a few extras in case of emergency, so if the 125 does blow I will have something I can put in for a quick fix. I've heard they blow when trying to jump a vehicle and the ends touch, with my luck I'd try helping someone and blow my fuse and run out of battery before getting home.
stykthyn
5,232
2,652
223
gainesville
Sep 16, 2014
#27
  • Sep 16, 2014
  • #27
Never seen a 125 blow. Only issues I've seen were poor connections causing shorts. If you pop a 125 you have something pulling some serious juice.
BKM48198
377
27
49
Ypsilanti, Michigan
Sep 16, 2014
#28
  • Sep 16, 2014
  • #28
Why would Ford put in a 175 amp fuse on a 130 amp Alternator?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,360
211
114
Ohio
Sep 16, 2014
#29
  • Sep 16, 2014
  • #29
This!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 17, 2014
#30
  • Sep 17, 2014
  • #30
For the same reason they undersized the foglight wiring on 87-93 Mustang GT's. It was cheap, or they got a bargain price on them, or they are mismarked.
Reactions: BKM48198 and stykthyn
BKM48198
377
27
49
Ypsilanti, Michigan
Sep 20, 2014
#31
  • Sep 20, 2014
  • #31
Got the Alternator, a 60in battery cable ( 4 gauge), fuse holder and fuse from Napa.....just have to put it all it.
BKM48198
377
27
49
Ypsilanti, Michigan
Sep 21, 2014
#32
  • Sep 21, 2014
  • #32
I put the 3G alternator in and when I turn on the defroster my AC kicks in, I hooked the stator wire up to the unused wire harness like ...7. Splice the new stator wire with a scotch lock to the small wire on the big electrical plug..........and I have no idea if that is correct or if it should be hooked up to the middle wire on the D-Plug that is used. On the Mustang it came off of the stator wire just went from the D-Plug to the Stator and there were only 2 wires going out from it, my OE wiring has 3 wires going back into the wiring harness.
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
Sep 21, 2014
#33
  • Sep 21, 2014
  • #33
I like Scotch Locks, but for something more than trailer lights or a cheap stereo, you really need a better connection. Electrical fires are no fun, and you are using a potential on something that controls a lot of electricity.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 21, 2014
#34
  • Sep 21, 2014
  • #34
BKM48198
377
27
49
Ypsilanti, Michigan
Sep 21, 2014
#35
  • Sep 21, 2014
  • #35
That was from another post about doing a 3G install, I would never use a scotchlock, solder is much better.
BKM48198
377
27
49
Ypsilanti, Michigan
Sep 21, 2014
#36
  • Sep 21, 2014
  • #36
jrichker said:
I was told that the AC runs when in MIX or Defrost, so I guess everything is good, I just never knew it would come on like that.
First Prev 2 of 2
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
