zZsKyZz said:
"this setup"
....is what exactly?
stock block, 331 ci, eagle crank, eagle rods, srp pistons, canton 7qt t sump pan, windage tray, main support, balancer, comps cam grind # fw nx274hr-14, scorpion 1.6 rockers, arp rod and main bolts, arp head studs, cometic head gaskets, ram aluminum flywheel, king cobra clutch, victor jr. heads, performer rpm II intake, 180 t-stat, bbk 75mm tb, 80mm mass air meter, afm power pipe, vortech s-trim (stock pullies), stock fuel rails, 50 lb injectors, aeromotive fpr, 255 in tank pump, walbro gsl392 inline pump, -8 feed line, -6 return line, mac long tubes, prochamber, flowmaster mufflers, mac 2.5 inch tailpipe kit, msd 6al, msd distributor and coil, msd cap and rotor, taylor 10.4 wires, autolite 3922's, performance distributors ignition module
