94/95 GT Intake/TB Parts (Trick-Flow, BBK)
I have the following parts in great shape; only selling because I upgraded to larger parts and converted to Fox style intake (Pictures to be added soon):
94/95 Mustang 5.0 BBK 70mm Throttle Body (P/N 1523 with factory TPS sensor tested and still good (Summit sells this for $210 without TPS sensor!) - $130 shipped
Same as this part: http://www.summitracing.com/parts/BBK-1523/
Trick-Flow 94/95 5.0 75mm 45° elbow (satin) - $65 shipped
Same as this part: http://www.summitracing.com/parts/TFS-5150SN95-00/
Extra brand new TPS sensor ($35 value; Duralast # TPS261 with 2 yr warranty) - $25 shipped
94/95 Throttle Cable (was replaced with factory Ford part a couple years ago) - $30 shipped
94/95 Cruise Cable - $25 shipped
5.0 302 stock Crankshaft (little rusty from storage but will clean up fine, no machining needed ran great in original engine!) - $50
Left side clear corner light for 94-98 (stock) - $5
Left side scoop for 94-98 (factory, behind door) - $15
Instrument cluster surround, black (94-98) - $10
Stock 2.73 gears for 8.8" differential - $5
Stock harmonic balancer, great shape just upgraded to racing spec - $25
