94-95 t-5 in a 88Gt
The input shaft is 5/8" longer on the 95 model T5. You would need the 95 bellhousing, clutch arm and possibly a mod to the rear transmission mount. The shifter would sit further back and the driveshaft yoke might bottom out on big bumps.
The other alternative is to use the input shaft from an 87-93 T5 with the same number of teeth on the input gear.
attachment.php
