The input shaft length is different on 94-95's (theirs are longer). It can certainly be made to work - it seems to me that there are a couple ways to do it.
Use the trans & bellhousing and you will have moved everything back about 3/4". That includes the shifter, rear trans mount and most importantly, the end of the output shaft. The extra lenght may cause problems with the driveshaft being too long. The yoke has splines to enable the driveshaft to move, but the extra 3/4" may be too much. The yoke may bottom out under certain conditions, and this could damage the transmission.
