94 Gt engine idle!
onesharpstang
I have recently removed my smog pump and tubing. Then installed EGR delete
plate,Mac long tubes, Pro chamber. Now at times while pulling up to stop light or just idling she wants to die. What should I do next to help with this?
Thanks!
Onesharpstang
I've got MAC Longtubes and Prochamber as well - love the sound, good choice. :)
Check the easy things first like exhaust leaks and vacuum leaks and read the codes - it's easy to knock a vacuum hose lose, I've done it before.
Next up, did you do something to address the CEL that gets thrown on a missing EGR?
If you did, I'd look at resetting your idle and EEC to see where that gets you - http://www.mustang-tech.org/wiki/94-95_Mustangs_Tuning_Idle.
Good luck and holler back if there's anything else I can help with,
Wes
