  • 1994 - 1995 Specific Tech
94 GT exhaust problem
  • Thread starter Thread starter 5.0 Cowboy
  • Start date Start date Oct 3, 2008
5.0 Cowboy
  • Oct 3, 2008
hey guys i just started my clutch replacement project today and i had a question about getting the factory mid pipe out. ive gotten everything un hooked except for a tube that appears that it comes from the egr down the side of the midpipe and then splits off into the secound set of cats. i loosend the clamp but i still cant get it off. what should i do and what is this? thanks in advance for the responces.
Tom95gt
186
South Jersey
Oct 3, 2008
  • Oct 3, 2008
I just sprayed some lube on it and kept prying at it... it should come oh and its a line from the smog pump and correct me if i'm wrong but it cools the cats i believe and pumps air into the exhaust
Zero_chance
1,244
Maricopa, AZ
Oct 6, 2008
  • Oct 6, 2008
Correct, the air is pumped into the cats to aid the catalytic process. Like said, theres really no "trick" save for maybe some penetrating oil and a lot of prying. Good luck.
94-302-vert
1,947
NE CT
Oct 7, 2008
  • Oct 7, 2008
I cut mine and then used a piece of heater hose with clamps to bridge it back together... I have been suing the same piece of hose for 4 years without a problem...
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 7, 2008
  • Oct 7, 2008
I did the same as 94-302-vert. No matter what I tried, it was not coming off of the cats, so I cut it. Been about 6 or 7 years for mine.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Oct 7, 2008
  • Oct 7, 2008
I cut mine and brought it in on my next scrap metal run. I probably got 1 and a half cents for it. I think this is the best use for that hose.
Kurt
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
M
  • mnky99
  • Sep 5, 2025
mnky99
M
