94 Gt Stalling Hard To Start When Hot
Stangusa
I bought someone else's project nice car, lots of performance upgrades, but low fuel pressure, replaced pump, replaced fuel filter, started up ran then got warmed up dropped pressure, changed, fuel control module, ran great, went for test drive to get gas, stalled, took 20mins to let set before it would start, feels like fuel issue.
Help.
Fuel control module? Do you mean the relay module, or something else?
But yes I agree with madspeed, 9/10 it's the TFI module or the PIP (pickup) in the distributor causing hot stalling & no-start until you cool off. Sadly the TFI will usually test fine as it only acts up when it heats up, so replacement is pretty much it. Luckily they're not that expensive. The PIP in the distributor is more of a hassle, many opt for a new distributor (it's definitely possible to change it yourself, but requires pulling the gear with the chance of damaging the shaft... and the bushing has probably seen better days anyways).
