94 Mustang Gt 5.0 (AM1/TAD)????
MarshallPhil3
34
I pulled my codes and i got 122,553, I read that 122 has to do with the tps low voltage. but what does 553 mean? Is it a sensor or what? Could it cause my car to barely go, hesitate, then get up and then go back to acting ****ty.
If anyone knows anything post it thanks
553: It's part of the smog system and should not cause your issues. The solenoid allows extra air to be introduced into the exhaust.
I'd be all over that TPS. Look for a dead spot in the reading (use your DMM to test the output along its entire range of motion).
The DMM should show a linear sweep from ~1V to ~5V. Yes, open the TB as slowly as you can so you can see every increment. If the reading falls to zero or does something weird and then comes back up, you've found an issue (deadspot).
