- Feb 7, 2010
- 0
- 0
- 0
i have a ? bout my 94 mustang gt if any one can help me just put the motor in will the 2 grounds that go to the fude box keep my car from turnin over and also keep fuel pump from kickin on also there are 2 post to hook the the starter wire on is there a certin one to hook it on cause wen i went to hook bothe wires to the fuse box they started to spark witch told me the wire on the start was on the wrong post am i right the wires that go to the fuse box arre onw white one and one red one also my trans was fine befor i put it in now and acts like its not shift right will that change once the car is started up and the trans warms up also the throw bearing arm is lose it only goes on one way once i put the clutch cable on it should be tight right or should it be lose with the cable not on it
