Hello fellow stang brothers, haven't posted here in a while but due to my current situation I figured I come on here and ask for some help. I recently purchased a 95 gt 5.0, two weeks into my ownership my block split at the crankshaft
so I found a used 5.0 HO from another 95 and replaced all possible gaskets, freeze plugs, water pump, hoses, rear and front seals before dropping it in. Timing chain checked out good when measured for slack so I left that alone. Engine is now installed and the following parts were purchased new, motorcraft plugs, msd cap n rotor, new wires, new maf, new intake air temp sensor, new coolant temp sensor, new air filter, new pvc valve, new fuel filter, new thermostat,new radiator cap, fluidyne radiator. Well the engine started on the first try and idled okay but when I tried to take off it had low power and sputtered but still somewhat driveable. Fast forward two days later now I can't even get her to stay on, it idles very rough, seems like a couple of cylinders aren't even firing and a very strong of cruede gas enough to make your eyes watery. The only way to keep her on is if I unplug the maf, iac, tps and intake air temp sensor and when I do this I get slight black smoke from the pipes. Tried pulling codes but the dash mode isn't working for me, don't know if am doing wrong or what...... Any help would be appreciated, thanks guys
