95 cobra...need recommendations
I wrote awhile ago, but spent the money I had on keeping my home, etc. I have a 1995 cobra with stock gt40 heads, cobra intake, LT BBK, OR H, Flo Catback, 65mm TB, 2031 cam Crane, stock roller rockers, CAI... I was thinking of getting aftermarket aluminum heads and roller rockers and having the stock cobra intake ported by tmoss. Any ideas on this? I want to retain the stock "look" but get into the 300+ rwhp club. ANy ideas. I am open to suggestions for anything. I want to do it right. N/A is the way I want to go. 100K on the car.
Thanks.:D
You already have crane 1.7rr from the factory on the cobra motor, Get some AFR 165s that use ped. mount and have the lower ported, then I would get some dyno time at a really good tuner that can burn you a chip.....if that's even needed. underdrives would be good to pull some extra power out of your combo too, umm....adjustable fuel pressure regulator for tuning is nice
58cc 165s that use ped. mount rockers if it were me, you get a bump in compression and can use the rockers you already have. NOW....if you plan on stroking it out later on down the line, you can get the 185s, but for a na 302, 165s are your best bet IMO
