Its down on power, not sure why. Im having a friend of mine look at it this week. Im wondering if the exhuast is the Problem. It has a off-road H and a Magnaflow exhaust. Im wondering if there is not enough Back pressure and that is why its lacking power. Check engine light was on, fixed the problems with that - No light but still no power. I did the battery disconnect also, still no power.
Any other possible issues, I know that the possibilities are endless and its hard to tell. Car is stock other than a cold air intake and a 70 MM TB
Cap ar rotor look good Maybe the coil?
Starts Fine runs fine comming to a stop light the idle is high then comes down in a bit.
will NOT brake the tires loose from a stop light, ok mabe a churp..
At speed you can burp the throttle and its responsive, although doing it faster gives a small "back fire".
Planning on doing a track event this weekend... Thats why I got the car.
Any help will be appreciated
