First of all I have a 95 cobra, 302, Trick flow top end with twisted wedge heads and stage 2 camshaft, stock maf, stock fuel pump, stock dizzy.
factory manifold headers, no cats, no smog pump.
These are the codes I have only after install of this motor. I have a chip with a tune on it, mail order. The car is extremely rich, runs doggy, off and on, It has fox throttle body, I have found no vacuum leaks. It runs like i have the timing way retarded or something but timing is at 10* and the chip is supposed to advance it.
212 Loss of ignition diagnostic monitor input to spark output circuit grounded, and 543, fuel pump secondary circuit failure batter to control module,
I can't find a loose or broken ground for the life of me!
i have a chip and burner, and binary editor and can email the tune to someone if they know what they are looking at....
I've tested every sensor... the only think I can think of now is maybe spout is bad, ecu could be bad, IDK why that would happen with new motor, or pickup in dizzy is bad?
Please help, any input is appreciated.
-Matt
-Matt
